Aug 18th, 2024, 4:17am
How to calculate and simulate impedance (Read 1506 times)
Larry_80
Apr 17th, 2013, 12:53pm
Hello Guys,
Please How do i find Zin by hand calculation. Also how do i simulate the frequency dependent Zin in hspice? I would like to see if my Zin is a function (strong/weak) of the DC bias point (Vref) of my amplifier.
raja.cedt
Re: How to calculate and simulate impedance
Reply #1 - Apr 17th, 2013, 1:22pm
hello,
I guess it should be nmos rather pmos.
use small signal analysis, you will get around (1/sCdecap)+(ro)+(ro*1/scdecap*gm*(1+A)), of course it depends on vdd but as long as you have vddmin the sensitivity will be very less.
Coming to simulation, you could use ac simulation, apply some ac voltage with proper dc voltage at vdd and find ac current.
Raj.
Larry_80
Reply #2 - Apr 17th, 2013, 1:31pm
Thanks Raja, i was able to do the hand calculation. I will try to do the simulation now. Could i possibly do a network impedance  simulation?
raja.cedt
Reply #3 - Apr 17th, 2013, 1:33pm
what do you mean by "network impedance  simulation"?
Larry_80
Reply #4 - Apr 17th, 2013, 2:39pm
raja.cedt wrote on Apr 17th, 2013, 1:33pm:
Sorry i meant like 2 port network analysis. Z11 will be the input impedance...considerng Vddm as the output.
raja.cedt
Reply #5 - Apr 17th, 2013, 2:53pm
yes, indeed that's very professional way of finding impedance at any node. Use S-parameter simulation or any two port sim and find the z11.
Good night.
wave
Reply #6 - Apr 18th, 2013, 3:30pm
What is this circuit trying to accomplish??
It looks like an attempt at a DC bias circuit.
Looks like there are problems.
Horror Vacui
Dresden, Germany
Reply #7 - Apr 19th, 2013, 12:35am
raja.cedt wrote on Apr 17th, 2013, 2:53pm:
Good night.
Wouldn't it be enough to apply the AC source across the port? Of course with proper termination at the other ports if they exists.
raja.cedt
Reply #8 - Apr 19th, 2013, 2:03am
yes, sufficient.
In fact i suggested the same in my first reply.
Raj.
