Aug 18th, 2024, 6:19am
Precision Analog Transimpedance Gain Control (Read 1560 times)
dannybeckett
Apr 15th, 2013, 6:20am
Hi guys,
First time posting here so, hello y'all =] Basically I need to control the gain of a transimpedance amplifier in a very clean and precise manor, for a capacitance meter I am designing. I'm going to be sensing currents down in the nA range, with an excitation signal of up to about 100KHz. The reason for such small currents is because the excitation amplitude cannot exceed ~10mV. This would be fine, but for my application the current flowing is about 20nA at low frequencies and up to about 50uA or greater at higher frequencies. This means I need to be able to control the gain of the transimpedance amplifier to select different current ranges. Does anyone have an expertise in this area of electronics design? I am currently considering using JFETs as resistors, reed relays to psychically swap out fixed precision resistors and possibly the use of a digitally programmable potentiometer. Sensitivity, capacitance and frequency response need to be considered!
Cheers for any help,
Dan
raja.cedt
Re: Precision Analog Transimpedance Gain Control
Reply #1 - Apr 22nd, 2013, 12:35pm
hello,
yes you are correct, some how you need to change the FB res, but a transistor with continuous may not be a good idea due to vds sensitivity and non-linear control. Your 2nd option digital control resister  was very good from practical point. Otherwise use logarithmic clipping which compress gain as function of log(current). You can refer the following pap.
130dB-DR Transimpedance Amplifier with Monotonic Logarithmic
Compression and a High-Current Monitor
Raj.
