Aug 19th, 2024, 2:14am
How to select between two signals, as the output (Read 2075 times)
guava
Apr 19th, 2013, 7:06pm
I've got three incoming signals; one is from a mic, one is from a comparator and the other is from an iPod. Depending on the value of the comparator, I want to output the signal from either the mic or iPod.
My idea is to use a 2:1 multiplexer, using a select line (signal from comparator). I want to do this purely using a analog configuration i.e nothing digital.
I don't know if this is the most practical way to go about it. I don't how I can do it using the multiplexer, if it is to be purely analog.
Any ideas?
raja.cedt
Re: How to select between two signals, as the output
Reply #1 - Apr 19th, 2013, 10:50pm
hello,
try to use transmission gate based  multiplexer.
Anand Kumar Rai
Bangalore
Reply #2 - May 5th, 2013, 9:51pm
You can use analog switch IC from Onsemi or Fairchild.
View Profile Anand Kumar Rai Anand Kumar Rai eldaas_anandrai   IP Logged
