Aug 18th, 2024, 10:27am
DLL questions (Read 3522 times)
Evgenii
DLL questions
Apr 22nd, 2013, 7:45am
Hi Folks!  :)
Maybe this post more suitable for Digital Design,  but anyway  i'm try...
I'm new in design of Delay Locked Loop, and i already have schematic solution .
After simulation i see some strange behavior, which i can not a explain...
First of all,  criterion of lock DLL (startup time) is absence of pulses (pulses are generated by PD), these pulses 'tells' to CP in which direction needs to realign VCDL. But on low frequences (some corners) i see that both pulses are presented in end-of-simulation and NO trend to decreasing one of them..What is it? Autooscillations of DLL? How to explain this problem and to solve...To solve I tried to increase capacitor in CP circuit, anyway it blindest solution...
On high frequences i see absence one of pulses, is good, but another pulse no  disappear, he decreased to final  amplitude. I think that is no problem, if propose, what she is smaller than treshold of transistor, and CP doesn't work with this amplitude.
I some disapointed Sad, may all of this artefact of transients simulation, but precision is highest... May be is my misunderstanding in optimal parameters of CP pull up/pull down current, CP capacitor , frequency ranges of DLL.
Thanks for help! Smiley
raja.cedt
Re: DLL questions
Reply #1 - Apr 22nd, 2013, 8:00am
Please explain  in-detail, better show show some PD,CP results or up and down pulse....without it is very tough to imagine your problem. Any how i guess you have problem with your PD, so please run a transient Sim and check weather output is in-phase or not. If they are not then i would say you better replace PD with-some verilog-A model and check the sim.
Raj.
Evgenii
Re: DLL questions
Reply #2 - Apr 22nd, 2013, 8:24am
Thanks!
NOLAP and GAP pulses are presented in every clock. This Fig for PSRR, some strange behavioral after VDD step from 3.3 to 3.6V (no pulses).  GAP and LAP between 1 and 8 (first and last output pulses)  looks like "swing"  :)
« Last Edit: Apr 22nd, 2013, 11:51pm by Evgenii »
Evgenii
Re: DLL questions
Reply #3 - Apr 22nd, 2013, 8:35am
with Ideal CP is eliminated problem with "swing" but at highest frequency part of NOLAP still try to realign VCDL...BTW, whats wrong may be with my PD,  is only simple logic with NAND and NOR gates...
Below i attach both CP
Evgenii
Re: DLL questions
Reply #4 - Apr 22nd, 2013, 8:54am
M10, M4 - for fast startup. Divider on diods has no influence on charge/discharge process. In 'swing' average of V_IBIAS is still constant.
Evgenii
Re: DLL questions
Reply #5 - Apr 22nd, 2013, 9:12am
And last spam today Smiley
Higher frequency. NOLAP has trends to saturation and no disappear...
Evgenii
Re: DLL questions
Reply #6 - Apr 22nd, 2013, 11:05pm
Sorry Smiley! What is mean: "check weather output is in-phase or not..."
