rajdeep
I am getting elaboration error when I try to run an AMS sim using irun flow of cadence.The error code is CUVPOM and its explanation is: "The indicated port was either not declared in the instanced module, or it was mentioned too many times in the connection list".
The actual netlist is quite large so giving an example here.
Say, blockA is instantiated as follows in top module. /////////////////////////////////////////////////////////////////// module TOP(in1,in2) begin output [1:0] in1; output in2; blockA u_blockA(.in1(in1), .in2(in2)); end
In the same cadence library block A is defined as: module blockA(in1,in2); begin output [1:0] in1; output in2;
endmodule ////////////////////////////////////////////////////////////////
No error is coming for in2, but for in1 which is a bus.
Can anyone please explain how to get rid of this. As I said the netlist is quite large and generated using VerilogIN of cadence from a synopsis generated netlist. No error or warning in verilogIn.
Thanks, Rajdeep
