Jul 19th, 2024, 8:24pm
AMS elaboration errr in irun flow (Read 4064 times)
rajdeep
UK
Apr 25th, 2013, 9:21am
I am getting elaboration error when I try to run an AMS sim using irun flow of cadence.The error code is CUVPOM and its explanation is:
"The indicated port was either not declared in the instanced module, or it was mentioned too many times in the connection list".
The actual netlist is quite large so giving an example here.
Say, blockA is instantiated as follows in top module.
module TOP(in1,in2)
begin
output [1:0] in1;
output in2;
blockA u_blockA(.in1(in1), .in2(in2));
In the same cadence library block A is defined as:
module blockA(in1,in2);
begin
output [1:0] in1;
output in2;
No error is coming for in2, but for in1 which is a bus.
Can anyone please explain how to get rid of this. As I said the netlist is quite large and generated using VerilogIN of cadence from a synopsis generated netlist. No error or warning in verilogIn.
Rajdeep
rajdeep
UK
Re: AMS elaboration errr in irun flow
Reply #1 - Apr 25th, 2013, 11:37pm
Hi All,
Just to close this thing, there was some port mismatch. Lesson learnt: whenever any such problem in Cadence AMS sims, try to open the concerned verilog files through the hierarchy editor! That tells exactly which designs it has picked up depending on the library definition. I was looking at wrong verilog files assuming the hierarchy editor was picking up them!
Rajdeep
