Jul 24th, 2024, 6:22am
Is there any method which set the resistor in Spice model ? (Read 1140 times)
azure_sky
Apr 30th, 2013, 1:26am
Thanks for reading.
I'd like to define the resistor between source and drain in spice model.
But I didn't find such a parameter in BSIM3 spice model paramter.
That I want to do is to make the leakage source which depends on VDS.
I don't want to change the other factors (Vth, Isat, etc).
Is there any method in hspice model ?
Re: Is there any method which set the resistor in Spice model ?
Reply #1 - Apr 30th, 2013, 2:12pm
There isn't such a thing in the official standard BSIM3.
Some vendors may have added a proprietary extension to the model, though I'm not aware of any.
raja.cedt
Reply #2 - May 1st, 2013, 12:55am
why don't you add in schematic level??
Reply #3 - May 1st, 2013, 8:49am
It could be a nuisance to do in schematic, if you have many instances.
Reply #4 - May 1st, 2013, 6:06pm
Can't you just create a subcircuit with the resistor and device model?
