Apr 28th, 2024, 8:35pm
Pages: 1 2
Theory to design a pierce oscillator (tough question) (Read 3765 times)
Kevin Aylward
Re: Theory to design a pierce oscillator (tough question)
Reply #15 - Jul 10th, 2013, 9:30am
The laws of physics demand that the voltage across a resister is in phase with its current. Possibly simulator needs to be set with tighter tolerances, and more time points, or Ken has built in a deliberate error in Spectre to annoy people. The rest of the xtal is all lossless components, hence cannot dissipate any heating power. All power in the XTAL black box must therefore be due to the resistor.
Kevin Aylward
Pictou
Reply #16 - Jul 11th, 2013, 5:14am
Thank you for your help, it does make sense!
PS : your tutorial on startup circuit is really well written, thank you for sharing this.
Reply #17 - Aug 2nd, 2013, 7:31pm
Couple things on simulating with a high Q crystal -
The high Q will lead to errors in resolution due to the extreme narrowness of the resonance.
(you actually miss the peak of the curve in the frquency steps, unless you get really small and thus slow simulations)
This also leads to really slow start times for transient simulations.
Tricks:
Drop the Q down a lot in the crystal model, this will speed simulation and you won't need micro steps when frequency sweeping. This will also speed you start-up time as oscillation builds.
Other useful item - instant start of the simulation instead of waiting for it to slowly build up - put an initial condition of current on the inductor in the crystal model. This will give you an instant start for the crystal.
THis has been discussed here before.
Kevin Aylward
Reply #18 - Aug 3rd, 2013, 1:28am
It would be a good idea to set up a parameterised model of the xtal. A generic model would be like:
.SUBCKT XTAL 1 2 c1=1p esr=50 f=10M c0=2p
Cp 1 2 {c0}
Ls 1 3 {0.025330295/f/f/c1}
Cs 3 4 {c1}
Rs 4 2 {esr}
.ends
In Cadence you can use the CDF to set a parameterised symbol for a schematic block. The inductor inductance field can contain the equation. The Q can then be varied as desired by changing c1. Typical c1’s will be from  1ff to 20ff for full Q, and 1pf for sims that finish this week.
Kevin Aylward
ricardo80
Reply #19 - Nov 1st, 2013, 10:03am
@Pictou: I think your simulation is ok if it works well and there is problem in the calculation of the frequency and if it does not work well try to adjust the values of R,L and C because the frequency of oscillation of the oscillator depends upon the these parameters.
Pages: 1 2
