Sep 17th, 2024, 1:58am
Assura QRC run problem (Read 3432 times)
emax00
Jun 11th, 2013, 8:23pm
The Assura QRC run fails after LVS match. The QRC was setup using QRC -> Setup QRC
In the Setup tab all Output Formats are selected and Set As Default is Extracted View. The Technology and Rule Set is selected correctly using drop down menu and Template File is not selected.
For the Extraction tab all Allow Extraction Types are selected and Set as Default is RC. Nothing is changed in rest of the tabs. Selecting OK pops up a message to overwrite Template File /opt/<design kit installation directory>/assura_<design kit >_tech/rcx/.rcx_setup.tpl
Everything seems ok till now, but when QRC is run... a pop up message says: No technology directory found. and next the Run Form opens with Technology selection disabled. The QRC fails after run with the following error log
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
Loading <design kit>/libInit.il ...
Loading <design kit>/loadCxt.ile ... done!
Loading context <design kit>' from library '<design kit>' ... done!
Loading context 'pdkUtils' from library '<design kit>' ... done!
Loading <design kit>/libInitCktPro.il ... done!
Loading <design kit>/libInitCustomExit.il ... Loading libInitCustomExit.il for <design kit> ... done!
Loaded <design kit>/libInit.il successfully!
INFO (LBRCXU-114): Finished /opt/assura412/tools/assura/bin/rcxToDfII
INFO (LBRCXM-642): Constructing the RCX run script
INFO (RCXSPIC-27050): Could not open file /home/rusr/cds_130n/lvs_run/RCXspiceINIT for reading
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): ***** QRC terminated abnormally *****
The actual name of pdk is replaced with <design kit> in the above log. I suppose some configuration is not correct as the same set of tools works fine with Cadence gpdk045. Please help to resolve this issue.
