Apr 27th, 2024, 12:00pm
Pages: 1 2
Getting Loop Gain of Boost Converter with UC3843 controller using SIMetrix softw (Read 33534 times)
kanmaedex
Jul 20th, 2013, 10:31am
Hi everyone I am trying to measure the loop gain of my Boost Converter (Vin = 15V, Vout = 30V, up to 10A load) using the free version of the SIMetrix software, SIMetrix/SIMPLIS Intro 7.00. I am measuring the overall loop gain (outer voltage loop, including the current loop) in order to check the phase and gain plots for stability purposes. The controller used is the UC3843 controller also available in SIMetrix.
The problem is I can't believe that I am doing the measurement right since the resulting plots are exactly the same regardless of whether I shut down the IC, change the compensation values drastically. The magnitude gain is very low ~ -50dB below at 1Hz up to 100kHz which is weird. It is weird since the resulting plots of output voltage curves are totally good and ok from no load up to 10A.
I used AC analysis. Attached here are images of the schematic, the options I chose in the Simulator->Choose Analysis window, and the plot which remains the same regardless of compensator values. The plots change when I change the load, but the magnitude gain is still very low.
I am concerned with whether or not I am doing the loop gain measurement correctly, or if this is a technical limitation of the software, or if this is a problem with the UC3843 model.
Some explanations to the schematic: input voltage is V1 (displayed as 15V in schematic), load is I1 (displayed as 8A in the schematic), C4,R15,C5 are the compensators Type II compensator, Q2 and R10 comprise the slope compensator, I used 3 parallel NMOSFETS IRF32105 each having Rg = 10 ohms and Rgs = 30kohms. V3 is the perturbation, and the probe used is the Bode Plot Probe.
Frank Wiedmann
Munich, Germany
Re: Getting Loop Gain of Boost Converter with UC3843 controller using SIMetrix softw
Reply #1 - Jul 20th, 2013, 3:46pm
You are indeed not doing the measurement right. See the section "Analysis of Linearized Circuit" of my web page https://sites.google.com/site/frankwiedmann/loopgain.
kanmaedex
Reply #2 - Jul 21st, 2013, 3:06am
Hey thanks for the reply! I read your site and from there I think I understand primarily the problem with my measurement. I guess it's really the different linear models that may boost converter has per switching state that makes the AC analysis invalid since the linear model is not 'time-continuous'.
I found the Simplis website and it shows how the loop gain/phase could be plotted using the SIMPLIS engine. I tried it and the response showed realistic results (attached here).
I just have a few more questions left:
1.) It did show realistic results up to half the switching frequency but greater than that the results showed unrealistic results like zigzag and some noisy curves. I was wondering if you have any explanation for it? It seemed like this also happens when you use a real network analyzer to measure power supply feedback stability based with my experience and I don't know why this is.
2.) I've read in a book, Pulse-Width Modulated Converters by Marian Kazimierczuk that the space averaged-state modelling works accurately only up to half the switching frequency but didn't really explain why this is so mathematically. Would you know of it? By the way, my switching frequency is at 100kHz.
3.) I've also found in your website explanations about opening the loop. In my experience with network analyzers I see that they use transformers, in injecting the noise/disturbance at the appropriate point in the feedback loop so that there will be DC isolation. Is this similar to it? I did not consider this (inductor and capacitor placement) in injecting my disturbance but in the SIMPLIS website demo for presenting the getting of loop gain he did not put inductors and capacitors so I'm not sure what really must and must not be done.
Thank you very much! I am also sorry for posting tons of questions but I am really eager to learn this. Thanks.
« Last Edit: Jul 21st, 2013, 6:01pm by Forum Administrator »
Frank Wiedmann
Munich, Germany
Reply #3 - Jul 21st, 2013, 4:13pm
Thank you for making me aware of this capability of SIMPLIS. I will probably update my web page accordingly.
Regarding your questions 1 and 2: I am not really an expert in switched-mode power supplies but I assume that this is due to aliasing. For an explanation of aliasing in samplers, see pages 15 to 17 of https://ccnet.stanford.edu/cgi-bin/course.cgi?cc=ee315b&action=handout_download&....
Regarding your question 3: The transformer creates a floating voltage source just like the one that is used in simulation. With this method, you measure/simulate voltage loop gain. See http://www.omicron-lab.com/fileadmin/assets/customer_examples/Bode_Info_LoopGain... for the conditions under which this is a good approximation for the loop gain.
Frank Wiedmann
Munich, Germany
Reply #4 - Jul 24th, 2013, 12:57am
As it happens, there is a discussion about SIMPLIS in the LTspice Yahoo Group right now at http://tech.groups.yahoo.com/group/LTspice/message/68551. The author, analogspiceman, is a very experienced SMPS designer. You might be able to get a better response to your questions 1 and 2 from him because he describes the effect in his message and seems to know more about it. You might want to contact him by email as discussions about topics not related to LTspice are frowned upon in that group.
kanmaedex
Reply #5 - Jul 24th, 2013, 3:28am
Thanks! Cheesy I learned a lot from this.
analogspiceman
Reply #6 - Jul 24th, 2013, 7:30am
kanmaedex,
I just read Frank's private email message and then registered here and I haven't run your simulation, but I can guess what is going on.
The boost topology can suffer from a right half plane zero and it appears that is the case for your design.  The cure is to make the inductor smaller and the output capacitor bigger.  Since it is just a simulation, I would make the inductor 33uH and triple the cap to 6m in series with 6m.  Of course, the current sense resistor may have to be adjusted to avoid peak current limiting (or not - didn't check) and the added voltage ramp might need to be increased (but just leave it alone for starters).
Next, your compensation network is probably not the best.  The match to the output capacitor ESR zero is wrong (lower the 4n7 capacitor's value to 2n2 or 1n5) and the parallel integrating cap is way too large (make it 10uF at most - 1uF or smaller would be better for the final design).
The "noisy folding" you see in the loop gain is just the expected characteristic of a SMPS, which, of course, is a sampled data system.  Even with no RHP zero and perfect compensation, the best your loop phase can do is hit zero at just half the switching frequency.  You can look at current mode control as a kind of zero order hold which leads to this characteristic (think of it either as non recoverable phase loss from delay or as aliasing of the perturbation frequency onto itself at fsw/2).  The SIMPLIS data looks a little ragged because you don't have enough points.  Tell SIMPLIS to take 10x or 100x as many points to get a clearer output plot.
When you do this, at the high frequencies you should see the phase change rapidly with vertical jumps as it wraps 360 degrees again and again.  I don't know if you can tell SIMPLIS to display the phase without the wraps - it actually is just diving precipitously nearly straight down beyond the switching frequency (because the increasing harmonics of fsw appear closer and closer on a log plot).
Hope this helps.  Please report back what you find.
analogspiceman
Reply #7 - Jul 26th, 2013, 7:07am
From staring at your second loop-gain plot over the last day or so while waiting for you to post an update, several observations and questions have come to mind.
First off, from the location in frequency of the first "tooth in the comb," it is apparent that the switching frequency is about 20 percent over the stated 100kHz target.  This agrees with the oscillator component selection chart on the UC3843 data sheet, which suggest that a charging resistor of about 4k7 (rather than 3k9) would yield the desired 100kHz operation frequency.
This boost convertor is operating at very near 50 percent duty cycle, yet there is not even a hint of a bump in the gain plot at the traditional point of current mode instability (half the switching frequency).  Doing a hand calculation, it looks to me like the slope of the compensation ramp is very roughly about twice the natural down-slope of the boost inductor, which is a good choice to suppress the current mode instability, but I would think that there still should be a slightly visible glitch at fsw/2 in the loop-gain curve.
With a 15V input, a 30V/8A maximum output load, and the given values for the boost inductor and and output capacitor, a right half plane zero should be evident in the loop-gain curve, but it is hard to clearly see its location because of all the other frequency effects going on.  Plotting I(D2)/I(L1) should make the location of the RHP zero clearly stand out and show how much phase margin it actually is eating.  Adjusting down the L/C ratio of the power stage components should push this RHP zero out to higher frequencies, but maybe it's not so bad as is and you can live with a slightly reduced loop bandwidth and slower step response, rather than change the power stage components.
This is a very simple circuit and should be easy to simulate in LTspice, both in the time domain and with an averaged model (including current mode control effects) for looking at loop response.  I don't know how to use SIMPLIS, but it's probably not hard to learn and might be very interesting to compare against the results produced by LTspice.
Maybe I should give it a go and post some curves here (time permitting, of course).
analogspiceman
Reply #8 - Jul 27th, 2013, 5:29am
Here is the boost circuit drawn using LTC's "equivalent" replacement part to the UC3843 (it performs nominally the same, except it has leading edge noise blanking).  Note that I have "optimized" the compensation circuit and tweaked the oscillator to run at 100kHz.  The simulation is set up to operate with 15V in and 30V out at 8A, then again at 0.8A output.
analogspiceman
Reply #9 - Jul 27th, 2013, 5:40am
Now here is the output for the basic boost transient simulation (LTspice).  Note that with the light load, that the integration capacitor in the compensation circuit "winds up" during start up, causing a small amount of overshoot such that the output completely turns off until the load bleeds it back down.  The run time for this stepped simulation was a little over a minute.
analogspiceman
Reply #10 - Jul 27th, 2013, 6:18am
Next, here is the ac loop-gain simulation schematic shown for the same boost circuit.  LTspice does not have the ability to run a frequency response analysis directly from the transient schematic like SIMPLIS, so for switched mode circuits, it is necessary to set up an averaged model.  This is a straightforward process once the theory is understood (but this is probably beyond the capability of most LTspice users).
One need only generate the basic duty-cycle averaged equivalent for the switched voltage and current, generate the equivalent PWM gain factor, generate the second order low pass "delay" network to approximate the sampling effects of a SMPS (this captures the subharmonic oscillation effect of current mode control) and then LTspice will do the rest of the "heavy lifting" in sorting out the complex frequency response.  LTspice faithfully captures how all the poles and zeros move around with changing line and load conditions, including the mysterious, ethereal right half plane zero that exists only because of the switching action.
Note that because this is a boost circuit (which is just a buck circuit run backwards), the duty cycle generated by the control has to be "backwards" as well, i.e., it is (1-d) rather than just (d) directly.  PWM gain depends on the sum of both the natural ramp of the sloping inductor current and the so-called "stabilizing artificial ramp."
analogspiceman
Reply #11 - Jul 27th, 2013, 6:31am
Now, here is the Bode plot output from the ac equivalent circuit in LTspice.  Shown are actually three very similar runs that differ only in the amount of compensating ramp added to the PWM node.  One has just enough added ramp to be right a the point of subharmonic oscillation, one has ramp with slope equal to the inductor down slope, and the most damped response is with twice that slope in the added ramp.  Also shown is the RHP zero picked out from the ratio of currents on either side of the boost power stage (it location moves with changes in line or load, but this simulation was always run at full load and nominal line).  Note how the magnitude response of the RHP zero curves up like a normal LHP zero, but the phase breaks in the opposite direction to a LHP zero.
analogspiceman
Reply #12 - Jul 27th, 2013, 7:06am
I downloaded the node-limited free trial version of SIMPLIS and was able to use it to simulate the same circuit.  Learning its human interface has been a challenge, but I am extremely impressed with its powerful ability to be able to simulate the ac response (loopgain) of a SMPS circuit directly from the transient model.  One does not have to know anything about how to generate averaged models and the like.  This is actually easy to do in LTspice once the technique and underlying theory is understood, but with SIMPLIS, the exact same schematic can be used for both transient and small signal analyses, so there is zero chance of making a mistake while generating an assumed "equivalent" ac translation.
Once I get a little better a manipulating the output and generating a clean schematic (and graphics file - haven't even begun to try that), I will post the results from SIMPLIS, but they seem to be in close agreement with LTspice.
Schematic capture, editing and manipulation in SIMPLIS is very different than in LTspice (editing is more like the standard Microsoft interface with regard to the detailed order of the editing actions) and SMIPLIS doesn't seem to have redefinable hotkeys, but I'd say that it is probably equally as good as schematic capture in LTspice.  Plotting results and manipulating the graphical output is another story, however.  There, I'd give LTspice the clear edge as it has powerful waveform math that is easy to use and edit after-the-fact (SIMPLIS seems to require deleting and replotting waveforms to "edit" them).
analogspiceman
Reply #13 - Jul 27th, 2013, 9:23pm
Okay, now I know my way around SIMPLIS well enough to generate a decent looking schematic.  This should be the same at the LTspice version.  No doubt there are slight differences in the details of the control IC model (for example the oscillator resistor required to run at 100kHz is slightly a different value).
analogspiceman
Reply #14 - Jul 27th, 2013, 9:45pm
Now here is a visual demonstration of why the time domain frequency analyzer loopgain response from SIMPLIS is better than any averaged approximation.  I have overlaid the SIMPLIS output (solid heavy red and green) onto the LTspice output (thin solid and dashed green).  The LTspice averaged model attempts to be realistic up to half the switching frequency (any mismatch beyond that is unimportant to compensation design).
The two curves are essentially the same at low frequencies (the small difference at very low frequency is probably due to mismatch in PWM IC models), but at near half the switching frequency the phase really does not match well.  This is due to the second order LCR approximation to the Zero Order Hold like response of the real PWM model - it is impossible to get a perfect match.  Making approximate averaged models is a tricky business and it is much safer just to get the response from the switched model.
All is not lost with the averaged model however, as in spite of the slight mismatch, it still can be used to predict the onset of subharmonic oscillations quite well.  But considering accuracy, ease of use and inherent immunity to modeling errors, SIMPLIS is a clear winner here.
Pages: 1 2
