Jul 17th, 2024, 10:22pm
parameters in analog function (Read 3366 times)
spinfab
Jul 22nd, 2013, 2:14am
Is it possible to get parameters (declare with: parameter real a 1.0) or globals variables (declare with: real b ) in an analog function without passing these var in the function argument.
instead writing if
  myAnlogFunction(x, a, b)
i would prefer it
   myAnlogFunction(x).
Thanks for your help
fab
Re: parameters in analog function
Reply #1 - Jul 23rd, 2013, 12:56pm
In the LRM (version 2.3.1) section 4.7.1:
An analog user defined function:
— shall only reference locally-defined variables, variables passed as arguments, locally-defined parameters and module level parameters; and
— If a locally-defined parameter with the specified name does not exist, then the module level parameter of the specified name will be used.
Sounds like you can get module-level parameters, but not variables.
spinfab
Reply #2 - Jul 24th, 2013, 12:02am
indeed but I got an error with spectre
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/3605_sdk_models_model_source_XXXXX.va.spitt_v1.ahdlcmi/Linux/../
ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
   ERROR (SFE-91): Error when elaborating the instance XXXX. Simulation should be terminated.
Reply #3 - Aug 2nd, 2013, 8:48am
You can check the Spectre documentation; maybe this is a known limitation.  Either way, you should contact them and demonstrate your need.
