spinfab
indeed but I got an error with spectre ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/3605_sdk_models_model_source_XXXXX.va.spitt_v1.ahdlcmi/Linux/../ ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem. ERROR (SFE-91): Error when elaborating the instance XXXX. Simulation should be terminated.
