Jul 15th, 2024, 11:41pm
Spice from Verilog using V2LVS command in Calibre (need to simulate) (Read 3342 times)
ic_engr
Jul 24th, 2013, 9:54am
Hello
I have a diigital GDS. I used 'v2lvs' command in Calibre to get the spice generated to perform LVS. All went okay.
I now want to perform simulation in Cadence in spectre. To do this,
I converted the spice file using 'spp -convert ...
and got the spectre file .scs.
When I simulated now, its complaining about "Unexpected equals "="/ Expected end of line".. this is happpening since the file has port assignments like a=adc_bit<0>. it seems it wants me to put the net into double quotes.
Any suggestions why ?
ic_engr
