Apr 28th, 2024, 12:51am
how to apply .vcd(.trn) stimulus to cadence schematic? (Read 8877 times)
visbi
Bay area,SF
Aug 01st, 2013, 5:58pm
Hi Friends,
I am just wondering if I can apply stimulus as vcd(.trn) file to cadence schematic. I have access to cadence 615 and generally use virtuoso AMS simulator fro simulating verilog and cadence schematic.
How can I provide inputs from vcd file to cadence schematic?
Any help is greatly appreciated.
-Thanks in advance.
Always in hurry
boe
Re: how to apply .vcd(.trn) stimulus to cadence schematic?
Reply #1 - Aug 2nd, 2013, 2:41am
visbi,
yes, you can use (E)VCD. Setup->Simulation Files.
- B O E
visbi
Bay area,SF
Reply #2 - Aug 2nd, 2013, 9:42am
Thanks for help. But could you please elaborate? I have a verilog symbol in my cadence schematic. I need to apply inputs as VCD . How to simulate using ADE ?
Always in hurry
eep
Reading, PA, USA
Reply #3 - Aug 5th, 2013, 11:27am
I've been looking into this myself recently. Most of the documentation is in the Ultrasim User's Guide. You need to create an info file to go with your VCD file which contains voltage thresholds, rise/fall times, etc. I would get it working on a small test case before trying your full circuit.
Reply #4 - Aug 13th, 2013, 9:09pm
Visbi,
 First need to separate the schematic tool, Virtuoso Schematic
Editor [VSE], from the simulator. From the schematic window,
can open the simulation environment window. From the simulation
window, you define the stimulus and specify your stimulus.
