Jul 25th, 2024, 3:30pm
deep nwell isolation effectiveness (Read 3015 times)
RobG
Bozeman, MT
Aug 8th, 2013, 6:21pm
Hi All,
I have a vague memory of someone (loose-electron?) saying they did some studies on deep Nwell isolation and found that the noise isolation improvements were minimal. Was the issue that you could not contact it at a low enough impedance? Any (decent) papers on the subject?
rg
« Last Edit: Aug 08th, 2013, 7:29pm by RobG »
Re: deep nwell isolation effectiveness
Reply #1 - Aug 18th, 2013, 11:56am
yes - we did some real world studies and the deep well does not help that much in most cases (2-4dB)
(IBM, SiGe processes with deep-n-well 6HP IIRC)
At high frequencies, coupling is going to be by parasitic paths and the deep wells do not make parasitics go away by magic.
