Apr 30th, 2024, 8:52pm
Self bias PLL (Read 7302 times)
raja.cedt
Self bias PLL
Aug 19th, 2013, 11:27am
Can any one please explain what is the the dis-advantage of self bias PLL (PVT robust), i haven't seen any one using self bias PLL now a days. Mostly i have seen supply regulated self bias many papers from Rambus, true circuits using this long back, but don't know why there are not using now.
Raj.
carlgrace
Berkeley, CA
Re: Self bias PLL
Reply #1 - Feb 23rd, 2014, 9:10pm
This is an old post but maybe someone is still interested...
The biggest problem with the self-biased PLL is that the oscillator isn't as fast as possible in a given technology.  Nowadays people want to go as fast as possible.  I use the self-bias PLL exclusively in my designs.  I understand it and it works.
I think it has only disappeared from the leading-edge research zone PLLs.  I suspect it is quite well-used in practice still.
