Sep 1st, 2024, 11:32am
How an amp would oscillate if it's phase margin blew 0 (Read 3741 times)
xianweng
Sep 01st, 2013, 9:16am
Hi ,everybody
If PM of an amp below 0,it will oscillate nearby Vref or from 0 to VDD or something else?
best regards
raja.cedt
Re: How an amp would oscillate if it's phase margin blew 0
Reply #1 - Sep 1st, 2013, 9:24am
Very difficult to ans, in fact phase margin is based on  small signal metric. But once if starts oscillating there is it would leave small signal regime and rest i can't predict, i guess it reaches very near to vdd and vss.
One more thing, according to linear system theory If Phase margin is -ve then pole will be in RH plane hence response would go in exponential increasing amplitude sinusoidal way and mostly it will touch rails and gain will drop down.
Raj.
xianweng
Reply #2 - Sep 2nd, 2013, 9:33am
Thank you ,I see
Fortion
Reply #3 - Sep 5th, 2013, 10:15am
hello raj can you please elaborate the reason of the negative margin
i always find it hard to understand?
raja.cedt
Reply #4 - Sep 5th, 2013, 11:01am
Imagine you have system with 3 poles and high gain, then 3 poles contribute 270 deg, but to be in -ve feedback region you can't have more than 180 hence -90 is the net margin.read razaavi text book.
buddypoor
Bremen, Germany
Reply #5 - Oct 1st, 2013, 9:32am
xianweng wrote on Sep 1st, 2013, 9:16am:
Hi ,everybody
best regards
When the PM is negative, there will be a lower frequency fo that exhibits a PM=0 deg.
This is the frequency where oscillations might occur. However, it depends on the loop gain magnitude at this frequency if you can observe oscillations or some other kind of instability.
