Aug 15th, 2024, 3:31pm
SpectreRF can't generate phase noise result but OK with "output noise" (Read 2100 times)
neoflash
Mixed-Signal
Designer
Sep 12th, 2013, 12:44pm
For some reason, spectreRF doesn't want to give me phase noise results in Direct Plot Form. However, it always give me output noise.
When I select phase noise item in GUI, tool tells me that " output nodes of pnoise analysis not saved for pss analysis. As a result, the above selected function cannot be executed."
What can cause this problem?
Neo
neoflash
Mixed-Signal
Designer
Re: SpectreRF can't generate phase noise result but OK with "output noise"
Reply #1 - Sep 12th, 2013, 2:45pm
OK, fixed by going newer version of Spectre.
