Jul 23rd, 2024, 10:34pm
SNDR in Current Steering DAC (Read 7295 times)
lvbq
Shanghai
Oct 08th, 2013, 6:01am
Hi all ,
Resently I have simulated the SNDR of a 12b Current sterring DAC ,but it is only 54dB, thus the enob is 9bit . Simulation by Cadence without mc model.
So, I'm very confused why the DAC's SNDR was so bad ?
Can anyone give me some help?
By the way, How to tradoff the transistors' size of current source for the Statics and Dynamic performance ?
View Profile lvbq   IP Logged
harpoon
Hampshire
Re: SNDR in Current Steering DAC
Reply #1 - Oct 8th, 2013, 6:20am
usually down to mismatch.
can you share some schematics and simulation plots ?
lvbq
Shanghai
Reply #2 - Oct 8th, 2013, 8:44am
It's Current steerining DAC .the decoder is 8bit MSB thermal and 4bit  binary .  cascode current source biased by Bandgap and V2I.
So, Why SNDR was so bad even without mc model?
Best regards!
harpoon
Hampshire
Reply #3 - Oct 9th, 2013, 1:16am
you have to be careful with drain voltages in a current steering DAC, esp for high res DACs. I am guessing the loading seen by the current mirrors are slightly different across the codes. I am guessing at some point, you cascodes are entering the linear region. Doesn't need MC to see that.
Could also be the mismatch between the 8bit and 4 bit sections ... check your switches.
Also, try replacing components in yr design with ideal ones to identify the issue.
I'm afraid that is the best we can do without schematics and test benches ...
good luck (you'll need it ... suggest you think about layout as well !)
lvbq
Shanghai
Reply #4 - Oct 9th, 2013, 8:41am
Thanks。
harpoon
Hampshire
Reply #5 - Oct 10th, 2013, 3:41am
hi lvbq,
if you do manage to get to the bottom of it, it would be good to know what it was and how you fixed it ...
all the best !
lvbq
Shanghai
Reply #6 - Oct 10th, 2013, 7:22am
harpoon wrote on Oct 10th, 2013, 3:41am:
hi lvbq,
all the best !
Just from pre-simulation without mismatch model,I found that the Large CS transistor‘s size can down the SFDR .
I think the dynamic impendance of the cascode current source becoming very low in high frequency(in Nyquist frequency)。
Therefore,There is a tradoff of the size of the current source (Is that called the tradoff between Static and Dynamic performance?)
My English just so so...I'm not a native speaker..I don't know whether you can understand what i mean。
harpoon
Hampshire
Reply #7 - Oct 11th, 2013, 1:36am
I am not sure I understand your email, but that's ok. Sounds like a sizing issue with your transistors.
I am surprised that you are getting speed issues with your cascodes, but then again, you'll be the better judge.
General rule of thumb ... size current mirrors to have a gm/I of ~10.
lvbq
Shanghai
Reply #8 - Oct 11th, 2013, 6:44am
harpoon wrote on Oct 11th, 2013, 1:36am:
gm/I ~10   that's means vdsat=0.2 ?
But the variation of I ~1/vdsat  ,therefore ,large vdsat can minimize the variation.
harpoon
Hampshire
Reply #9 - Oct 11th, 2013, 7:25am
just a rule of thumb ... try hunting down the following doc for more details.
“Scalable GM/I Based MOSFET Model”
Proc. Int. Semicond. Device Research Symp., pp. 615-618, Charlottesville, VA, December 10-13, 1997
it is the basis of the EKV modelling a while back ...
