Jul 23rd, 2024, 12:24pm
performance curves (Read 2734 times)
smwk
Pakistan
performance curves
Oct 09th, 2013, 10:58am
I have a BLA6H1011-600 LDMOS avionics power transistor datasheet. The data sheet contins some performance curves which makes some sense to me. After these curves there is a heading which says "Curves measured under Mode-S ELM pulse-conditions". What does this statement means?
harpoon
Hampshire
Re: performance curves
Reply #1 - Oct 10th, 2013, 3:48am
Hi smwk,
if you have to ask those questions, then you may not be looking at the right components/parts.
a google search revealed the following result ...
http://www.radartutorial.eu/13.ssr/sr24.en.html
I am very curious as to what you are working on and where in the world you are ...
Wink
