Apr 25th, 2024, 9:06pm
Control signal circuits for shift register measurement. (Read 99 times)
Jacki
Oct 21st, 2013, 1:45am
   I am designing a PCB board for my chip now. Since I have a shift register inside the chip, I have to consider how to input the signals from the PCB board to the shift register. Should I use a labview, or are there any circuits I should add on the PCB board? Do I need to make an additional small board to control the shift register? I am not familiar with this part, any comments are appreciated.
   Jacki.
Jacki
Re: Control signal circuits for shift register measurement.
Reply #1 - Nov 20th, 2013, 5:56am
   I wonder if I can use pattern generator to generate both the clock and data for my shift register.
  Thanks.
  Jacki.
Jacki
Reply #2 - Dec 11th, 2013, 4:32am
Now I am using a MCU to generate the control signals. I don't think pattern generator can work for a shift register with many bits.
