Sep 1st, 2024, 7:13pm
Calculation Of Zin of audio filter (Read 1540 times)
Giorgos
Nov 10th, 2013, 3:57am
Hi ! I want to calculate the Zinput of this circut. What i am doing with Capacitors?Also, the Zinput until which devices is? maybe until first OPA ?
My frequency is 20khz.
Many thanks
http://i1284.photobucket.com/albums/a578/fovos1/SISOFILTE_zps56bc4977.png
aaron_do
Re: Calculation Of Zin of audio filter
Reply #1 - Nov 10th, 2013, 5:12pm
that's a Sallen-key low-pass filter. I'm guessing you're talking about the in-band Zin. In that case, you can treat the capacitors as open circuit. Your input impedance is just the parallel combination of the two biasing resistors (looks like R1 and R3 but its difficult to make out). Nearer to the 3dB frequency, your input impedance will reduce.
cheers,
Aaron
