Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 23
rd
, 2024, 2:18pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› impact of SFDR
Previous topic
Next topic
impact of SFDR (Read 2664 times)
VNF
impact of SFDR
Nov 12
th
, 2013, 9:14am
I wonder what is the real impact of SFDR by itself?
e.g. two ADCs having the same SINAD, one has a better or wrose SFDR than the other, then how is that difference in SFDR reflected in the end?
thanks,
Kev
IP Logged
aaron_do
Re: impact of SFDR
Reply #1 -
Nov 12
th
, 2013, 11:52pm
In the context of a communications system, it affects your bit error rate.
regards,
Aaron
IP Logged
rfmagic
Re: impact of SFDR
Reply #2 -
Nov 23
rd
, 2013, 3:44pm
As SINAD determines the ENOB of the two converters the bit error rate will probably be the same for both.
If SFDR is different between the 2 converters it means that SINAD is dominated by non-linear distortion while the other converter is dominated by random noise. Based on this information you can determine how and what to improve in the circuit level in order to get better SINAD.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
