Jul 22nd, 2024, 6:21pm
Bootstrapped switch body tie (Read 8868 times)
aaron_do
Nov 28th, 2013, 11:46pm
I was attending a talk by a distinguished professor a few days ago, and he was talking about bootstrapping for a switch. The question that came up was how do you tie the body terminal of your switch? The professor's answer was the best place to tie it is to ground.
Now I didn't think of it at the time, but now I'm wondering if there's going to be a reliability issue. The gate of a bootstrapped switch could be swinging as high as 2VDD, and if you tie the body to ground, you're going to have 2VDD across the oxide. To me that's a big no no. Does anybody have any comments on this (whether there is a reliability problem, or the best way to tie the switch body)?
thanks,
Aaron
rfmagic
Re: Bootstrapped switch body tie
Reply #1 - Nov 30th, 2013, 11:56am
I would say that the risk for potential breakdown is higher with the bulk connected to ground but there is some relaxation here. The voltage at the gate with the bootstrapping can reach 2VDD but this is peak-to-peak voltage. The rms will be much lower and from my experience it will not degrade reliability too much.
In my  personal opinion connecting the bulk to ground is not a good suggestion as you will break the bootstrapping mechanism. The Vt modulation will degrade the linearity performance of the switch. IF you connect the bulk to the source you have all the nodes "floating', maximizing the efficiency of the bootstrapping.
aaron_do
Reply #2 - Dec 1st, 2013, 5:32pm
Hi rfmagic,
thanks for the reply. For the reliability part, my understanding is that it's not correct to look at the rms voltage. The reason is the time-to-failure of the device reduces exponentially with the gate voltage. i.e. having a duty cycle of 50% simply means your device will last 2x longer than the same device with a DC bias of 2VDD (as opposed to the same time as a DC bias of √2VDD.. That said, I have seen papers where their experimental data shows that if your signal is an RF signal, the time-to-failure is much longer (memory effects maybe?). My switching speed is on the order of a couple of hundred MHz.
I agree with you about the Vt modulation. However, if you connect the body to the source/drain, I believe there is a possibility of the junction diode turning on when the switch is supposed to be OFF. I have found a solution for my particular implementation of the bootstrapped switch, but it isn't pretty. My main question is really how come there is no reliability issue. Maybe its because the professor's work is too academic?
Aaron
boe
Reply #3 - Dec 2nd, 2013, 2:11am
Hi Aaron,
if Vgate>VDD, the switch is ON, so gate stress (in settled condition) relates to the channel voltage, not the bulk voltage.
- B O E
aaron_do
Reply #4 - Dec 2nd, 2013, 4:52pm
Hi boe,
sounds logical  ;) thanks
Aaron
RobG
Bozeman, MT
Reply #5 - Jan 12th, 2014, 8:13pm
When boot strapped switching was new there was a lot of talk about reliability, but it must not be a problem given its ubiquitous use nowadays.
Excluding active circuits, the only way I know to tie the bulk to a non-ground place is to place two switches in series and tie the bulk to the center point. But then each switch has to be 2x wider to get the same overall resistance... I'm willing to bet you would get better performance by simply doubling the width of a single switch and leaving the bulk tied to ground.
aaron_do
Reply #6 - Jan 13th, 2014, 7:05am
Thanks for the reply. I guess you're right about the reliability. Its just that I was thinking of other ways to tie the body, and I was wondering if the way the professor tied the body was the most common way.
Aaron
Reply #7 - Jan 13th, 2014, 6:33pm
If it is NMOS the bulk is already substrate to ground. Only PMOS will give you the freedom to float the bulk.
But thats a vanilla Nwell Psubstrate CMOS process.
aaron_do
Reply #8 - Jan 13th, 2014, 9:20pm
I have access to deep nwell. Wouldn't that be common for ADC designs?
Aaron
edit: just realized I didn't mention anything about ADCs in this post...
Reply #9 - Jan 15th, 2014, 4:19pm
aaron_do wrote on Jan 13th, 2014, 9:20pm:
Aaron
Depends on the process, its all connected together one way or another.
Even SOI has some coupling.
