Aug 14th, 2024, 10:55am
Problem with ASSURA pin names (Read 4754 times)
pinkfloyd
Jan 22nd, 2014, 10:02am
Hello.
I am using AMS hit kit and I noticed that the only way to create labels and pins is to go to hit kit utilities, create label and then use the tool create pins from labels.
I did it but when I try to run the LVS, in case I do not connect physically the metals that have the same pin and label ( for example VDD) it does not work, even if they have the same label and pin.
So, only when I connect it passes the LVS but when I want to import the cell in my whole design I have to remove the metals.
What do you propose?
Thank you in advance
Re: Problem with ASSURA pin names
Reply #1 - Jan 23rd, 2014, 3:41am
Search in the Assura documentation for "?joinPins". This is the avParameter to allow you to set up "virtual connections".
pinkfloyd
Reply #2 - Jan 24th, 2014, 11:36am
Not really....
http://asic.ams.com/hitkit/hk410/assura/assura_qrc.html
The only way to pass the LVS even if I join the pins is to really do a metal connection....
Is there another way?
Reply #3 - Jan 25th, 2014, 6:04pm
That's not the documentation of the tool - that's the kit documentation.
If using Assura for an IC61 release you can run $ASSURAHOME/tools/bin/cdnshelp and then search for ?joinPins.
Alternatively (and this will work for Assura intended for use with IC5141 too), look at $ASSURAHOME/doc/assurauser/assurauser.pdf and search for ?joinPins.
?joinPins allows you to set up a virtual connection without having to strap it in metal yourself.
Kind Regards,
