Jul 22nd, 2024, 2:18am
ADC Unit Capacitance (Read 13578 times)
aaron_do
Jan 26th, 2014, 5:34pm
just wondering, is it practical to have a very small unit capacitance? I am working on a SAR ADC, and while the minimum unit cap in the PDK is about 1.7 fF, it would be better if I could have something even smaller. However, with all the parasitic cap around, I'm wondering if its a bad idea. I've done some simulations, and the parasitic capacitance at the comparator node doesn't seem to affect the SFDR even when its mismatched. However, I haven't simulated any input cap non-linearity. So if the comparator node's capacitance changes with the input signal then I might be in trouble...
Also, I know its possible to add a series cap in the DAC array, but this would degrade the linearity, so I want to avoid that if possible.
Any input is welcome.
thanks,
Aaron
RobG
Bozeman, MT
Re: ADC Unit Capacitance
Reply #1 - Jan 27th, 2014, 8:39am
Wow, that is a small cap. Usually the cap-DAC isn't realized using super small capacitors for the LSB. Instead it is done by splitting the cap dac with a series capacitor. I'd be more worried about noise coupling into the node than mismatch, since mismatch of the LSB can be quite large (~ 50%).
aaron_do
Reply #2 - Jan 27th, 2014, 4:52pm
Hi RobG,
thanks for the reply. Yeah I'm aware of splitting the cap DAC, but this degrades the linearity. So I want to avoid it if possible. I ran monte carlo simulations on the cap mismatch alone and it seems good enough. Not sure about noise coupling though...I guess its one more thing I will have to think about.
So do you have an opinion on the minimum capacitance size that should be used?
thanks,
Aaron
Reply #3 - Jan 27th, 2014, 5:07pm
Time to refresh your memory on KT/C noise.
aaron_do
Reply #4 - Jan 27th, 2014, 5:31pm
Hi loose-electron,
I'll have another look, but I don't think its a bottleneck for my particular implementation. I'm just wondering if there's anything else stopping me from using such a small capacitor. Just for a quick check...
assume 12 bit with 1-V reference, LSB2/12 = 5n V2
kT/C = 5n => C = 0.8pF, so LSB cap = 0.8 pF/212 = 0.2 fF.
Have I made a mistake somewhere?
thanks,
Aaron
boe
Reply #5 - Jan 28th, 2014, 2:06am
Aaron,
C=0.2fF => kT/C = 20u V2 for the LSB cap.
Also remember that charge injection is highly critical on so small a cap.
- B O E
aaron_do
Reply #6 - Jan 28th, 2014, 4:58pm
Hi boe,
thanks for the tip about the charge injection.
I don't really get your point on the kT/C noise though. Are you implying that the LSB cap needs to be large enough so that its kT/C noise is less than the quantization noise? If so, I think I would disagree since in a SAR ADC, the sample and hold is performed on all of the caps together.
Aaron
RobG
Bozeman, MT
Reply #7 - Jan 28th, 2014, 7:09pm
aaron_do wrote on Jan 27th, 2014, 4:52pm:
I've never ventured below 25 fF so I have no experience to offer. I wouldn't go less than the minimum 1.7 fF cap in the PDK unless you really know the process. I'd think parasitics from your metal lines could easily introduce significant errors - more than using a cap splitter.
The charge and/or noise contribution by the LSB cap is down by 2-N so I don't think kT/C will matter.
boe
Reply #8 - Jan 29th, 2014, 5:13am
aaron_do wrote on Jan 28th, 2014, 4:58pm:
Hi boe,
Aaron
Aaron, you are right regarding kT/C noise - I was a bit too fast on that one.
- B O E
aaron_do
Reply #9 - Jan 29th, 2014, 5:04pm
Happens to us all.
BTW, I just finished reading "A 1.7 mW 11b 250 MS/s 2-Times Interleaved Fully Dynamic Pipelined SAR ADC in 40 nm Digital CMOS", which was written by some researchers from IMEC. On page 2, quote, "the total size of the fine SAR DAC capacitance is 62 fF, limited by the size of a unit capacitance". Given that its a 7b SAR, I read that to mean that the unit capacitance is 62/(2*2^7) = 0.24 fF. However, the picture indicates the biggest capacitor is a 16x unit cap (doesn't make much sense to me since that wouldn't be 7b), and that would put the unit capacitance at roughly 1 fF.
So apparently it is possible to use very very small capacitors...
regards,
Aaron
carlgrace
Berkeley, CA
Reply #10 - Jan 30th, 2014, 10:09am
A super small unit cap might be ok for a research project but I would be cautious using one for a production part.
I tried using really small unit caps on a converter a few years ago (noise spec was relaxed) and ended up getting much worse matching than estimated by monte carlo.  If you're using MIMs for best matching you need to be close to where the foundry actually measured data.  Extrapolation is dangerous.  If you're using fringe caps calibration is mandatory since most foundries don't track that.
Reply #11 - Jan 30th, 2014, 10:20am
Generally your minimum capacitance size will be driven by a bunch of things:
kT/C noise
Charge injection of switches
Matching accuracy
Interconnect parasitics
Perimeter parasitics (for smaller device they are a bigger part of the total)
Foundry limitations
Did I forget anything?
RobG
Bozeman, MT
Reply #12 - Jan 30th, 2014, 10:50am
loose-electron wrote on Jan 30th, 2014, 10:20am:
kT/C noise
Matching accuracy
Foundry limitations
Your desire to keep your job  :). I've learned to use my cleverness to decrease risk, not to do something merely because it is more clever than before.  Unless it is a really cool idea of course.
aaron_do
Reply #13 - Jan 31st, 2014, 5:51am
Actually if i dont use a very small cap, then i probably need a bridge cap (its a SAR). Based on my simulations, the ADC linearity is degraded enough using the bridge cap that it would mandate calibration even in the nominal case. So my motivation for using such a small cap is to have some confidence that the design will work even if the calibration has issues. Now im a little worried its gonna backfire...anyway i will figure something out.
Aaron
carlgrace
Berkeley, CA
Reply #14 - Mar 7th, 2014, 8:44pm
RobG wrote on Jan 30th, 2014, 10:50am:
This is some of the best advice I've seen in a long time.  I think focusing on risk and being very nervous about being "clever" is a sign of a mature designer.  There's a reason almost all of my Pipelined ADCs use 1.5 bits/stage.
