Quote:Correct me if I'm wrong, but I don't think adding a ground wire between the two leads would help since it is magnetic coupling.
Hi RobG,
my previous group did quite a bit of study on this a while back so I can share a little of my experience. The coupling coefficient of 0.4 is quite reasonable. Also, regarding the perpendicular bondwires, sometimes it looks like the bondwires are perpendicular, but from a 3D perspective it turns out that they're not that perpendicular. This is more true when the chip is quite high so although the bondwires appear to be going in different directions, it turns out that they're both just going downwards.
As for putting ground downbonds in between, it can help, but as I remember you need to be careful. Basically inductance is always calculated around the whole loop, otherwise it is just partial inductance. Therefore you need to consider the return path. If you use a ground bondwire close to your signal bondwire, and they are tightly coupled, then the loop inductance will be reduced. The lower inductance will result in less coupling to other bondwires.
However, if you share the ground bondwire with other circuits, then you might end up just coupling noise through the shared ground. Also, the ground bondwire must be a current return path. If you just leave one end dangling it may not have any effect.
Aaron
