Jul 21st, 2024, 8:26am
Pages: 1 2
Band gap +LDO transient measurement not in line with simulation (Read 484 times)
Re: Band gap +LDO transient measurement not in line with simulation
Reply #15 - Mar 26th, 2014, 11:30am
Heating?
I really doubt it.
Look at the time constants of your reference voltage and bandgap.
Also, the diodes in the BG often do not have their capacitance in the model, and if you have small bias current the time constants can be really off.
Lex
Eindhoven, Holland
Reply #16 - Apr 2nd, 2014, 1:46am
I share skepticism with Jerry..
I have heard many designers excuse themselves with "thermal response, package stress, substrate noise" and other things that are difficult to check, while for most times the problem turned out to be obvious things like low PSRR, poor settling speed or capacitive coupling.
So how did you do the MC verification? How did you define in simulation whether the BGR is settled? Did you simulate long transients as your measurement result? Are all nodes settled in the simulation?
RobG
Bozeman, MT
Reply #17 - Apr 2nd, 2014, 7:17am
Lex wrote on Apr 2nd, 2014, 1:46am:
I'll add models to that list of things that get blamed when it is really a something in layout, or a heat gradient Wink. Whatever you think it is, definitely be skeptical of your hypothesis and verify it thoroughly.
rg
Reply #18 - Apr 2nd, 2014, 5:14pm
http://electronicdesign.com/products/simulation-vs-silicon-avoid-costly-mistakes...
give that a read and see if it rings any bells on stuff you left out.
high impedance nodes with unaccounted for capacitance attached to it would be my best guess.
boe
Reply #19 - Apr 7th, 2014, 4:05am
I have already seen a circuit with a start-up time of about 10 seconds [sic!] due to charging of a cap with a MOS in sub-threshold region.
- B O E
Pages: 1 2
