May 6th, 2024, 6:52am
2D vector (i.e. array) as an input for an analog function? (Read 3691 times)
Vince Lee
Feb 24th, 2014, 3:21pm
Hi, I wonder if it is possible to pass a 2D vector into an analog function as an input argument? e.g.
analog function myfunc;
   input x[0:2][0:2];
   real x[0:2][0:2];
endfunction
Thanks!
Re: 2D vector (i.e. array) as an input for an analog function?
Reply #1 - Feb 25th, 2014, 12:44pm
There's an example in LRM 2.3.1, section 4.7.1:
Example 3 — Initialization of a vector variable
The analog user defined function called arrayadd adds the contents of a second array to the first.
  analog function real arrayadd;
    inout [0:1]a;
    input [0:1]b;
    real a[0:1], b[0:1];
    integer i;
    begin
      for(i = 0; i < 2; i = i + 1) begin
        a[i] = a[i] + b[i];
  endfunction
I can't say whether it works in all simulators.
