Aug 15th, 2024, 9:18am
tune out a wideband balun? (Read 1558 times)
mixed_signal
Mar 01st, 2014, 10:23pm
I am trying to implement a wideband balun as an intermediate stage in a CMOS receiver.
I want to have  Real(Zin)=Rload where Zin is input impedance looking to primary when secondary has a load Rload in 1:1 balun with l1=l2=1nH and k=1 . (ideal)
Is it necessary to tune out the inductors of the balun? I yes then it becomes a narrowband system.
If I dont tune then Zin, Real (Zin) becomes inductive and has very low real part.
aaron_do
Re: tune out a wideband balun?
Reply #1 - Mar 9th, 2014, 8:44pm
Hi mixed_signal,
you do need to resonate the balun in order to minimize loss. However, as I remember it, the balun will give you a wider bandwidth than if you had used an LC. Also, for high impedance ratios, baluns are also less lossy. I wish I had my previous references with me so I could give more information, but it would be quite a chore finding them since I changed jobs.
There are papers on power amplifier design which do a lot of analysis on baluns if you are interested. If I remember correctly, look for an author named Ichiro Aoki formerly from Axiom...
regards,
Aaron
