Aug 16th, 2024, 11:43am
simulation LC vco phase noise with supply noise (Read 3784 times)
880321
Mar 16th, 2014, 11:48pm
Hi;
I want to find the supply noise contribute to  the lc vco‘s phase noise;
I do two simulation:
1. the lc vco's supply is connected to a ldo output, then do PSS+PNOISE;
2. run noise simulation,get the ldo output noise and save as a noise file (V^2/Hz) "vddnoise.txt"; then use ideal sourse in analogLib "vdc", and include the noise file "vddnoise.txt", then do PSS+PNOISE;
the phase noise result in case 1 10 about 10dB better than case 2.
Anyone know the reason???
Thanks.
Shady Adly
Egypt
Re: simulation LC vco phase noise with supply noise
Reply #1 - Mar 18th, 2014, 9:04am
Yes, this is probably because your noise file doesn't reach zero at the end of the frequency of interest. So noise at much higher frequencies which doesn't exist in the real LDO and folds back on your signal frequency. This depends on the maximum sidebands you chose in your pnoise analysis.
Say you are interested in LDO noise until 1GHz, and lets say it is 1nV/sqrt(Hz) then the final frequency you type in the noise file is 1nV/sqrt(Hz) at 1GHz, but what you should really do is after that type 2GHz and set noise value to zero to terminate your noise file, or else your noise file will continue with 1nV/sqrt(Hz) until infinite frequencies as white noise, and folds back on you which is not the real case.
View Profile Shady Adly shady.adly   IP Logged
880321
Reply #2 - Mar 18th, 2014, 6:28pm
Thanks Shady, that is the case, the noise at high frequency fold back.
