Apr 27th, 2024, 12:13pm
Parent Child Instantiation (Read 8099 times)
Davivilla
Mar 21st, 2014, 9:05am
Hi
I am working in cadence IC 5.1 and i need to do a module with submodules, but in the language reference manual the example is not clear. can you help me?
This is the example of LRM of verilog-a.
module comparator(cout, inp, inm);
    output cout;
    input inp, inm;
    ground gnd;
    electrical cout, inp, inm;
    parameter real td = 1n, tr = 1n, tf = 1n;
    real vcout;
analog begin
    @(cross(V(inp) - V(inm), 0))
   vcout = ((V(inp) > V(inm)) ? 1 : 0);
   V(vcout) <+ transition(vcout, td, tr, tf);
module integrator(out, in);
    output out;
    input in;
    electrical in, out;
    parameter real gain = 1.0;
    parameter real ic = 0.0;
    analog begin
    V(out) <+ gain*idt(V(in), ic);
module sigmadelta(out, ref, in);
    output out;
    input ref, in;
    comparator C1(.cout(aa0), .inp(in), .inm(aa2));
    integrator #(1.0) I1(.out(aa1), .in(aa0));
   comparator C2(out, aa1, gnd);
   d2a #(.width(1)) D1(aa2, ref, out);// A D/A converter
Why the parent module is instiantiated at the end?
If i create this example cadence only recognize the fisrt module as parent.
Does parent module need to have a symbol?
Does All the modules needs to be created with symbol?
Does the modules need to be in any special place?, like the same library.
Can the parent module contain some description or only the instantiation?
boe
Re: Parent Child Instantiation
Reply #1 - Mar 21st, 2014, 10:06am
Davivilla wrote on Mar 21st, 2014, 9:05am:
Hi
Why not?
Every module should be defined as its own cell.
If you want to use it in a schematic, yes.
No. Quote:
Same library makes sense, but is probably not necesary [never tried that].
Yes, you can add as many comments as you like.
- B O E
Davivilla
Reply #2 - Mar 21st, 2014, 10:26am
Hi  B O E,
Thank you,
The problem is when i save the model, cadence recognize the first module instantiation as a parent. But obviosly the  parent is at the end.
Then the symbol of the model has the imputs and outputs of the first module instatntion.
Best regards
Reply #3 - Mar 24th, 2014, 12:26pm
I think BOE was suggesting that each module definition should be placed in a separate file, then it won't be a problem that only the first module in the file is recognized.  It's a little more work to create the files, but shouldn't be too onerous.
Davivilla
Reply #4 - Mar 25th, 2014, 6:29am
Thank  you Geoffrey_Coram.
I want to take a look at this code.
This is the parent:
// VerilogA for test_zjerarquia, padre, veriloga
`include "constants.vams"
`include "disciplines.vams"
module padre(entra, sale);
inout entra,sale;
electrical entra,sale;
hijo1 h1(entra, in);
hijo2 h2(salida,sale);
This is the child1:
module hijo1(entrada, salida);
inout entrada, salida;
electrical entrada, salida;
parameter gain=10;
analog begin
V(salida)<+ gain*V(entrada);
And this is the child2:
module hijo2(in, out);
inout in, out;
electrical in, out;
parameter polo1=10;
analog begin
V(out)<+laplace_np(V(in),{10},{6.28e-6, 0, 62.8e-9,0});
All modules are created in the same library.
Everyone has an associated symbol.
The final code is the union of all in that order ie.
inout entra,sale;
parameter gain=10;
analog begin
inout in, out;
electrical in, out;
parameter polo1=10;
analog begin
finally when i simulate, i do not get results.
Thank you and
Best regards
Davivilla
Reply #5 - Mar 27th, 2014, 8:46am
Hi
Look guys I found the solution for those who may be of interest.
The solution is create a unique the module for parent.
This module should contain only the mapping of ports and parameters of the child.
Th The syntax for this issue is:
inout entra,sale;
parameter carrier=1;
parameter gan2=1;
electrical aa; // wire
hijo1 #(.gain(carrier)) h1(entra, aa);
hijo2 #(.gain2(gan2))   h2(aa,sale);
Thank you all for the help.
