Apr 27th, 2024, 9:33pm
Why IC temperature is limited to 150 degree? (Read 4408 times)
angel
Mar 26th, 2014, 12:09am
Hello every one. I would like to ask one question. When we design IC chip, or read the datasheet, we can often see the IC operating temperature is limited to 150 degree. I would like to know the reason for it. Could you please give some evidence for it? g.g., paper, article, book...
Johan Dijkhuis
Re: Why IC temperature is limited to 150 degree?
Reply #1 - Apr 10th, 2014, 9:24am
When going above this temperature numerous reliability problems pop up, some of which are:
-purple plague at aluminium bondpads with gold wires (see http://en.wikipedia.org/wiki/Purple_plague)
-electro-migration in aluminium gets very problematic (http://en.wikipedia.org/wiki/Electromigration)
-NBTI and PBTI can get very high (http://en.wikipedia.org/wiki/Negative_bias_temperature_instability)
Some none-reliability problems:
-leakage can get very high
-transistor models might be less reliable (they are not tested)
Usually the design manual specifies reliability at different temperatures, and usually 150 C is a lot worse than 125 (if it is specified at all, a lot of processes are supposed to stay at 125 C maximum).
The 150 degrees limit will be based on history, it is not a hard limit but common process qualification stops at 150, so above that you'll have to re-qualify the whole thing. It might also be very hard to get it pass unless it is only at 150 C for a short time, and you might get unknown reliability problems.
Johan Dijkhuis
Reply #2 - Apr 10th, 2014, 2:03pm
Just found some useful links in this thread: http://www.designers-guide.org/Forum/YaBB.pl?num=1394735572. NASA has really extreme requirements, but some mission lifetimes are hours, not years.
