Aug 15th, 2024, 7:47am
current driven devices (Read 3096 times)
Mir
Kashmir
Apr 17th, 2014, 11:01am
current driven devices require low supply voltage .. why?
With Regards
aaron_do
Re: current driven devices
Reply #1 - Apr 17th, 2014, 8:31pm
more info.
Mir
Kashmir
Reply #2 - Apr 18th, 2014, 12:14am
like if i design a current driven LNA .... it will require less voltage supply as compared to that of Voltage driven LNA..
i had read it in many research papers but was unable to find the reason
With Regards
aaron_do
Reply #3 - Apr 20th, 2014, 6:01pm
When you think about current-mode or current driven, a current source has a high output impedance, and it ideally drives a circuit with a low input impedance. This will result in the maximum amount of current going from the source to the load. On the other hand, a voltage mode would be a low source impedance driving a high input impedance which results in the maximum voltage across the load.
Current-mode is therefore associated with low-impedance nodes which results in low voltages. So you need less supply headroom to maintain linear operation. But one of the fundamental rules of engineering is the no free lunch principle   Tongue and so you have to look at what you're trading for this better linearity (usually noise performance and power consumption).
Aaron
Mir
Kashmir
Reply #4 - Apr 20th, 2014, 8:42pm
thnxs... Smiley Smiley
With Regards
