Nov 7th, 2026, 9:32pm
How to plot phase difference in Transient Analysis (Read 11623 times)
DoYouLinux
Apr 22nd, 2014, 4:02am
I am trying to plot the phase difference between two sinusoidal signals in Transient Analysis using Virtuoso Waveform Calculator in Cadence. But, I could not find any function that can plot a phase difference ....
Please suggest
Thanks a lot,
DYL  ;)
Shady Adly
Egypt
Re: How to plot phase difference in Transient Analysis
Reply #1 - Apr 22nd, 2014, 9:40am
There is a function called "delay" you can use it to get the get the delay in seconds then divide it by the period and multiply by 2pi to get the phase difference.
Shady
View Profile Shady Adly shady.adly   IP Logged
DoYouLinux
Reply #2 - Apr 25th, 2014, 12:38am
Hi Shady,
Thanks a lot Smiley Never tried it before ... Will it give a time delay between two sinusoidal signals ?
DYL
Reply #3 - Apr 26th, 2014, 12:55pm
You specify the threshold crossing for the two signals - so you can measure the difference in time for the "zero crossing" of your two sine waves.
The definition of what the delay function does is covered in the documentation.
DoYouLinux
Reply #4 - Apr 27th, 2014, 11:57pm
Hi Andrew,
Thanks a lot for your suggestions, I'll try this Smiley
DYL
VK
Reply #5 - May 19th, 2017, 6:34am
Hi, I am working on phase shifting an output signal to 90°. How can I do it?
Reply #6 - May 28th, 2017, 8:59am
The forum guidelines ask you not to post in old threads, especially when the topic is rather different!
In general, a wideband phase shift is hard to achieve in general (because it's not physical). However, with some knowledge of your system, maybe it's possible - but your question is very vague.
