Jul 19th, 2024, 6:23pm
Pages: 1 2
Bandgap Temperature Coefficient susceptibility to packaging stress (Read 10716 times)
Lex
Eindhoven, Holland
Re: Bandgap Temperature Coefficient susceptibility to packaging stress
Reply #15 - May 14th, 2014, 1:44am
Anything you can spot in the layout that can cause extra differential stress? E.g. STI, metal. (or such as Rob mentioned lack of dummies etc).
Did you double check with the foundry for feedback on the processing conditions. Even the big ones make mistakes: I had once a large offset on poly, with a different tempco than provided in the corner models.
boe
Reply #16 - May 16th, 2014, 2:37pm
Ic_engr,
stress-related effects can even depend on position on the die, orientation on die, etc...
- B O E
Pages: 1 2
