Lex
Anything you can spot in the layout that can cause extra differential stress? E.g. STI, metal. (or such as Rob mentioned lack of dummies etc).
Did you double check with the foundry for feedback on the processing conditions. Even the big ones make mistakes: I had once a large offset on poly, with a different tempco than provided in the corner models.
