Zorro
Dear Designer's Guide Team.
I have a verilogams module. I want to use the @(final_step) built in event to check "only once at the end of simulation" if the value of a signal is high or low (1'b1 or 1'b0). The restriction is that I want to use this inside the digital context i.e. not inside an analog begin...end block.
Why? The module generates a log file, which is defined in the digital context and I am writing some data in that log file inside the digital context. In other words, that variable belongs to the digital context. I can use the @(final_step) inside the analog context, but I cannot write data to the log file because the analog context can read but not write that "digital" variable.
Of course I can define another log file into the analog process, but I want to avoid this, I want to avoid that for every module not one but two log files need to be checked.
Explanation of the code
I want to monitor if an analog signal is inside a given range. There is an internal variable vdda_v_flag which is initially 1'b0 and becomes 1'b1 if the analog signal to be monitored enters into the defined ranges and this variable vdda_v_flag remains 1'b1 in such a case. If the analog signal never enters into the defined ranges, then the variable vdda_v_flag remains 1'b0.
The code looks like this:
parameter real vdda_v_HiRange = 1.5; // Maximum vdda_v level (V) parameter real vdda_v_LoRange = 1.0; // Minimum vdda_v level (V)
parameter real dv = 1n; // Safety margin for voltage threshold crossing (V)
reg vdda_v_flag;
initial begin vdda_v_flag = 1'b0; end
integer output_file;
initial begin output_file = $fopen("log_file.txt"); end
always @( above(V(vdda_v)-(vdda_v_LoRange)) or above((vdda_v_HiRange)-V(vdda_v)) or // vdda_v rises above the low threshold or falls below the high threshold above((vdda_v_LoRange-dv)-V(vdda_v)) or above(V(vdda_v)-(vdda_v_HiRange+dv)) // vdda_v rises above the high threshold or falls below the low threshold ) begin if ( (V(vdda_v)>=vdda_v_LoRange) && (V(vdda_v)<=vdda_v_HiRange) ) begin vdda_v_state = 1'b1; vdda_v_flag = 1'b1; end else begin vdda_v_state = 1'b0; if (vdda_v_flag==1'b1) begin $fstrobe(output_file, "WARNING: V(vdda_v)=%gV is exceeding the defined safety ranges at time=%gus\n", V(vdda_v), $realtime); end end end
previous code is working fine. Now I want to check the value of vdda_v_flag "at the end of simulation".
I want to use this code:
always @(final_step) begin if (vdda_v_flag==1'b0) begin $fstrobe(output_file, "WARNING HIGH SEVERITY: V(vdda_v) was outside the defined voltage ranges during the complete simulation"); end end
The code compiles without errors.
But when I run the simulation errors are encounted:
Error found by spectre during circuit read-in. ERROR (VACOMP-1974): ".../verilog.vams", line 231: Unsupported analog event in digital context. ERROR (VACOMP-1816): Exiting AHDL compilation. ncsim: *F,INTERR: INTERNAL EXCEPTION Observed simulation time : 0 FS + 0
So my question is: how can I check in the digital context the final value of a signal at the end of simulation in verilogams???
Thank you!
