Jul 19th, 2024, 12:25am
8-bit 50MS/s ADC architecture choice (Read 2757 times)
neoflash
Mixed-Signal
Designer
Jun 14th, 2014, 10:28am
The requirement is to have 50MS/s data throughput. I have two choices:
1. pipelined ADC
2. 8-way interleaved SAR
The technology will be on 0.18um. Which topology will be more efficient in power/area?
Neo
Re: 8-bit 50MS/s ADC architecture choice
Reply #1 - Jun 14th, 2014, 6:15pm
probably a pipe will get it done in less space - interleaving a pile of converters brings up a bunch of problems beyond just power and area.
plenty of papers on the topic out there, time to start doing some research
neoflash
Mixed-Signal
Designer
Reply #2 - Jun 14th, 2014, 8:48pm
loose-electron wrote on Jun 14th, 2014, 6:15pm:
Thank you for your reply. The application seems to sample DC signal and greatly relieves timing mismatch issue.
Given this case, is SAR more attractive?
Reply #3 - Jun 20th, 2014, 7:48pm
8 interleaved SAR devices is a big headache in alignment and matching
Reply #4 - Jun 20th, 2014, 10:40pm
Hi Neo,
Why do you design a 50MS/s ADC to sample DC signal? What's your application?
Yawei
