Jul 18th, 2024, 9:58pm
slew rate calculation for a two stage op amp (Read 4123 times)
anhnha
Earth
May 12th, 2014, 8:49am
Could you explain a bit why slew rate is calculated by that formula along with that assumption?
I know that slew rate is defined as the maximum rate of change of output voltage per unit of time and is expressed as volt per second.
However, the lecture below give that formula without any explanation is a bit confusing.
anhnha
Earth
Re: slew rate calculation for a two stage op amp
Reply #1 - May 12th, 2014, 9:26am
Please look at this and tell me if it is correct or not. Thank you.
leon_O
Chennai
Reply #2 - May 15th, 2014, 1:03am
The output of the first stage is very small compared to that of the second stage. So, voltage across C_c is approximately output voltage. When I5 flows through this capacitor, output voltage ramps up/down with slope I5/C_c. I5 is the maximum source/sink current from the first stage which flows through C_c. The assumption that I7>>I5 is there because the slew rate is not limited by the second stage current.
ylc
Tianjin China
Reply #3 - Jun 29th, 2014, 7:52pm
anhnha wrote on May 12th, 2014, 9:26am:
I think this is the right answer.
dipper
