nat
Warsaw
As with everything there is alternative approach.
You can use XF analysis, then you won't have to play around with AC sources at supply.
I've learned this method from nice presentation by Jonathan David from Cadence titled Characterizing Differential Amplifiers for Communications Circuits - Measuring Performance with Simulation for First Pass Success. You can find pdf by googling the title.
