Jul 17th, 2024, 5:21pm
Dynamic Latch Comparator (Read 3211 times)
farsheed
Aug 01st, 2014, 11:16am
I want to know that, propagation delay is an important factor for designing a dynamic latch comparator. Can someone explain why the factor is so important and how much delay is expected/expectable as the output result?
carlgrace
Berkeley, CA
Re: Dynamic Latch Comparator
Reply #1 - Aug 1st, 2014, 3:21pm
The propagation delay sets the maximum frequency of operation for the latch.  You want the decision to propagate as fast as possible so you can clock the comparator as fast as possible.
How much delay is expected depends entirely on the process you are using.
farsheed
Reply #2 - Aug 2nd, 2014, 10:02am
Thanks for the reply. I am using CADENCE 0.18um process and I'm getting 4.2nS as the delay for my design. My design is able to run for 50MHz. Is this response ok?
carlgrace
Berkeley, CA
Reply #3 - Aug 4th, 2014, 11:11pm
Probably but it depends on that you're using it for.  It's not fast enough for a 50 MS/s pipelined ADC for example, but it could be fine for other applications.
RobG
Bozeman, MT
Reply #4 - Aug 6th, 2014, 2:19pm
To expand... propagation delay isn't fixed - with small inputs it gets larger and larger. With a small enough input it won't trip in time and you will get an error. The problem is called metastability. You need to figure out how small an input you can handle and jump through some formulas to convert it to a bit-error-rate.
Designer's guide actually has a paper on it... http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ve...
