May 5th, 2024, 10:35am
SAR ADC noise and comparator resolution (Read 4223 times)
vodka69
Jul 17th, 2014, 5:48pm
For SAR ADC, how to decide the minimum resolution of the comparator? How to tackle the noise in the design? Thanks
RobG
Bozeman, MT
Re: SAR ADC noise and comparator resolution
Reply #1 - Jul 18th, 2014, 11:20am
Well, it has to be less than 1/2 LSB, hopefully you can make it 1/10 LSB and let the quantization noise dominate.
eternity
Reply #2 - Jul 22nd, 2014, 8:13am
Adding to the comment above, if you are going for differential architecture, the minimum resolution of comparator can be doubled which relaxes the design limits relatively.
Regarding more stuffs on noise specfications of comparator or in general regarding SAR ADCs, please refer to the online PhD(free edition) by Pascal Meinerzhagen. He had probably covered all the aspects to its maximum.
Eternity
jockeymonto
abu dhabi
Reply #3 - Jul 23rd, 2014, 6:36am
Hi, The above two comments are very useful. Generally you would start with the required resolution of you analog input to the ADC. By that I mean what is the amplitude difference between two adjacent sampled inputs which you want your ADC to allot two different adjacent digital codes. Obviously this determines the ADC resolution or the required LSB. Say this required resolution or LSB is around 2mV. The ADC required resolution is then obviously 9 bits. Generally the resolution of an ADC should be such that it makes quantization error (plus minus half an LSB) of ADC insignificant so that we can accommodate the inaccuracies introduced by other circuit elements in the ADC like the comparator. So unless I know what is your required analog resolution, I can't say anything about comparator resolution. Pick an ADC with LSB 10 times lower than the required analog resolution; resolution of comparator will then be LSB of the picked ADC.
