May 4th, 2024, 5:27pm
Spectre RF PAC analysis for PLL closed loop model (Read 1544 times)
dark_knight
Bangalore
Jul 21st, 2014, 1:29am
I want to analyze the effect of VCO open loop noise getting aliased due to down-sampling by feedback divider. Until now I have been using a s-domain based PLL closed loop model using ideal components. I feed the VCO open loop noise into this model at the appropriate point to get the closed loop noise output. But this doesn't capture the effect of aliasing. So can I use a PSS+PAC analysis in SpectreRF to capture this effect ?
