Aug 16th, 2024, 7:54pm
Pages: 1 2
Relaxing the matching requirement in first stage of Pipeline ADC (Read 4982 times)
SNIKE
Jul 22nd, 2014, 12:35am
Hi Members,
I have a question in pipeline ADC's.
I am designing the following bits per stage
4bits per stage first stage followed by 9 1.5 bits/stage.
There is a digital correction so end number of bits is 12Bits.
Since the first sub ADC already resolved the MSB's, does this mean that my first MDAC/gain stage capacitor matching requirement is only 9Bit and not 12 bit?? Since only the residue plot is sent to subsequent stages?
Please enlighten me on this?
Thanks in advance.
aaron_do
Re: Relaxing the matching requirement in first stage of Pipeline ADC
Reply #1 - Jul 22nd, 2014, 1:22am
if you split up the operation, you can think of it as first calculate the residue and then amplify. In that case, the residue needs to be 12b accurate wrt the full scale input of the ADC, but only 9b accurate wrt the maximum swing of the residue. After amplification, it needs to be 9b accurate wrt full scale. But anyway I guess you can't look at an actual MDAC so simply. Of course, the output after amplification needs to be 9b accurate wrt full scale.
regards,
Aaron
SNIKE
Reply #2 - Jul 22nd, 2014, 1:31am
Yes I was thinking on the same lines.
The "Residue" needs to be 12 bit, which doesn't depend on capacitor matching. The residue is a sample of vin and DAC out, and at this point the ratio of capacitors still don't come in to picture.
The gain depends on capacitor matching, which requires to be only 9bit.
Let me know if my thinking process is wrong.
carlgrace
Berkeley, CA
Reply #3 - Jul 22nd, 2014, 5:41pm
I'm confused by the terminology you and Aaron are using.  Typically "residue" refers to the analog MDAC output, so the cap matching is part of it.  If you think of the residue of a stage as an analog representation of the quantization error of the stage's sub-ADC it should be obvious that converting more bits in a stage relaxes the requirements on the MDAC of that stage.
So, if you have a 4-bit first stage (i'm guessing it's really 3.5-bit??) then, yes, your MDAC only needs to settle to 1/2 LSB @ 9 bits.
SNIKE
Reply #4 - Jul 22nd, 2014, 6:04pm
thanks carl,
by  "residue" I meant Vin-Vin_digital.
I should have clarified it.
Sai
carlgrace
Berkeley, CA
Reply #5 - Jul 22nd, 2014, 10:28pm
hmmmm.... vin - vin_digital is not actually a term that exists in the ADC.  Did you mean vin minus the analog form of the reconstructed vin_digital?  This is what is typically called a residue.
Recall that in practical pipelined ADCs the sampling, gain, and subtraction are done by a single circuit (the MDAC) so the idea of vin - vin_digital doesn't have physical meaning.
If you're designing the ADC in a standard way the residue accuracy requirement of the first stage would be 9 bits.
SNIKE
Reply #6 - Jul 22nd, 2014, 11:33pm
Yes I meant Vin-VdacOutput.
In my head I am trying to imagine in following way:
Step 1) Vin is sampled on a capacitor.
Step 2) Vin is partially digitized by sub ADC, this code is converted in to Analog form [ for example + vref , 0 or -vref].
step 3) subtract Vin - Vdacoutput.
Step 4) send them trough a gain stage. This gain stage depends on capacitor ratios, so matching matters here.
even tough some steps occur simultaneously , the above steps help me understand the concept.
Now with your help and Aaron's I understand it fully.
carlgrace
Berkeley, CA
Reply #7 - Jul 23rd, 2014, 10:25am
You're almost there!
Main change I would make to your list is that the step four happens at the same time as steps 2 and 3, so the capacitor ratios matter for all three steps.  The reason we use redundancy (such as the 1.5-bit stage) is so that capacitor mismatch in steps 2 and 3 don't affect the overall performance of the converter.
aaron_do
Reply #8 - Jul 23rd, 2014, 6:29pm
Hi Guys,
first off, carlgrace would know this far better than me....  :P
Anyway I did mention that in a real MDAC you can't look at the operation so simplistically mainly because as carlgrace said the operations happen at once.
I have one question though.
the residue of the MDAC is digitized by the rest of the ADC which can be modeled as a lower resolution ADC. If the residue is non-linear, then how can redundancy help to correct it? I thought that redundancy corrects for sub-ADC errors.
thanks,
Aaron
carlgrace
Berkeley, CA
Reply #9 - Jul 24th, 2014, 6:05am
Hi Aaron,
I should have been a bit clearer.  The 1.5-bit stage means that cap mismatch doesn't cause nonlinearity in the subDAC (because any two points are linear, or three in a differential sense).  So, the only place cap mismatch hurts you is in the gain function of the MDAC when you're using a 1.5-bit stage.
If you're using a multi-bit stage, then you're right, mismatch in the DAC can cause issues.   Thanks for pointing that out.
RobG
Bozeman, MT
Reply #10 - Jul 29th, 2014, 3:42pm
A major part of his question hasn't been answered. Unless you want to calibrate, the first stage capacitor matching does need to be 12 bits. The opamp open loop gain also has to be greater that 2^12 (72 dB). This will ensure that the output of the first MDAC is at least 9 bit accurate.
Also - a minor point, redundancy is used so that the comparators in his 3.5 bit sub-ADC don't have to be 12 bit accurate. Cap mismatch (and low opamp gain) will only cause an error in the gain of the MDAC as Carl pointed out, but that gain error will limit the performance unless it is calibrated out.
aaron_do
Reply #11 - Jul 29th, 2014, 7:45pm
there needs to be a "like" button or something like that so we can see how many people agree with the comment.
Anyway for the opamp, the gain needs to be even higher to take into account the closed-loop gain right?
Aaron
RobG
Bozeman, MT
Reply #12 - Jul 29th, 2014, 8:15pm
aaron_do wrote on Jul 29th, 2014, 7:45pm:
A bit higher so that isn't the limiting factor, but the loop gain doesn't figure into it (to first order). For example, suppose you had a 72dB open loop gain opamp. This is (barely) good enough for a 12 bit ADC. (Actually I guess it might need to be 78dB to get within 1/2 LSB.) If you wanted to get 1.5 bits in the first stage your gain would be two and your loop gain would be 66dB. This isn't a problem because the output only has to be good to 11 bits. Similarly, if you were doing 3.5 bits in the first stage you'd want a gain of 8, resulting in a loop gain of 54dB. Again, this is ok since the output only has to be accurate to 9 bits. Does that make sense?
In the real world you'd want more margin... I take as much as is easily achievable so I don't have to worry about it over corners. Or whether it is 72dB or 78dB Smiley. Also, the input capacitance of the opamp reduces the loop gain.
SNIKE
Reply #13 - Jul 29th, 2014, 8:22pm
"What if we needed much higher resolution than 10 bits?
– Digital calibration
– Multi-bit first stage
• Each extra bit resolved in the first stage alleviates precision
requirements on residue transition by 2x
• For fixed capacitor matching, can show that each (effective) bit
moved into the first stage
– Improves DNL by 2x
– Improves INL by sqrt(2)x
• Multi-bit examples: [Singer 1996] [Kelly 2001] [Lee 2007]
B."
This is from Stanford 315B course by Boris Murmann.
I am confused, this is opposite to the comments in the thread.
RobG
Bozeman, MT
Reply #14 - Jul 29th, 2014, 9:21pm
Snike - Murmann's observations seem consistent with everything said here.
Pages: 1 2
