Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 9:33am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› ideal transformer impedance tranformation character varies with frequency
Previous topic
Next topic
ideal transformer impedance tranformation character varies with frequency (Read 1289 times)
dog1
Aug 07
th
, 2014, 6:34am
Hi:
I added an ideal transformer in cadence, add a resistor to one end, and is expecting to see the impedance transformation character at the other .
But the resistance I saw on the other end varies with frequency. Why is that? Shouldn't it be the same because I have an ideal transformer with k=1?
When k = 1, I should have
Vo/Vin=N
Io/Iin=1/N
And because Vo/Io=R
Vin/Iin=R/N^2 right?
Thanks!
IP Logged
aaron_do
Re: ideal transformer impedance tranformation character varies with frequency
Reply #1 -
Aug 7
th
, 2014, 6:57pm
you can model the transformer like this:
http://en.wikipedia.org/wiki/File:TREQCCTHeyland-to-k.jpg
i.e. you still have an inductance in your model which appears in parallel with the resistance. Since k = 1, you could look at re(Y11) and it should be frequency independent.
cheers,
Aaron
IP Logged
nrk1
Reply #2 -
Aug 7
th
, 2014, 7:16pm
For a mutual inductor to behave like an ideal transformer, you need k=1, and w*L2 >> R (where R is connected to the side with inductance L2). When w approaches R/L2, the impedance is no longer frequency independent. Some info is at the link below.
http://www.ee.iitm.ac.in/~nagendra/EC1010/201301/lectures/20130402/20130402.html...
IP Logged
dog1
Reply #3 -
Aug 11
th
, 2014, 3:50am
yes, I get it, thanks for both of your help
IP Logged
Reply #4 -
Aug 11
th
, 2014, 11:48am
What you have modeled is a 'closely-coupled inductor', which, as you have seen, is not an ideal transformer. If you want an ideal transformer, use the ideal transformer. It is in analogLib.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
