Jul 3rd, 2025, 3:50am
3.3 V to 1.8V level converter (Read 5489 times)
aman gupta
India
Aug 10th, 2014, 8:37am
I want to convert a square wave with high level of 3.3 V & low level of 0V to a square wave of high level of 1.8 V and low level 0V. Frequency of square wave is 1 MHz in one case and 25 MHz in other case. I have the circuit for the converter as shown in the figure. I simulated this circuit both in LT Spice & Tina. The circuit simulation is working for 1MHz signal but with some delay. And it is not working for 25 MHz. May be because switching time of BJT is high as compared to period of the signal. Suggest some alternative for that or any modification in the circuit. And also I am reluctant to use any SMD level translator IC.
raja.cedt
Re: 3.3 V to 1.8V level converter
Reply #1 - Oct 7th, 2014, 2:14am
Try to check opamp closed loop bandwidth or please show 3 node signals....
or thy this structure which is very common for LV to HV...
Raj.
aaron_do
Reply #2 - Jan 6th, 2015, 11:59am
If this is a CMOS IC, you can just use I/O transistors in an inverter configuration. In your circuit, the 22k/15k ohm resistors could be limiting your bandwidth...
Aaron
