Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Mar 27
th
, 2023, 12:46am
Home
Help
Search
Login
Register
PM to admin
Measurements
Other Measurements
› 3.3 V to 1.8V level converter
Previous topic
Next topic
3.3 V to 1.8V level converter (Read 4394 times)
aman gupta
India
Aug 10
th
, 2014, 8:37am
I want to convert a square wave with high level of 3.3 V & low level of 0V to a square wave of high level of 1.8 V and low level 0V. Frequency of square wave is 1 MHz in one case and 25 MHz in other case. I have the circuit for the converter as shown in the figure. I simulated this circuit both in LT Spice & Tina. The circuit simulation is working for 1MHz signal but with some delay. And it is not working for 25 MHz. May be because switching time of BJT is high as compared to period of the signal. Suggest some alternative for that or any modification in the circuit. And also I am reluctant to use any SMD level translator IC.
IP Logged
raja.cedt
Re: 3.3 V to 1.8V level converter
Reply #1 -
Oct 7
th
, 2014, 2:14am
Try to check opamp closed loop bandwidth or please show 3 node signals....
or thy this structure which is very common for LV to HV...
Raj.
IP Logged
aaron_do
Reply #2 -
Jan 6
th
, 2015, 11:59am
If this is a CMOS IC, you can just use I/O transistors in an inverter configuration. In your circuit, the 22k/15k ohm resistors could be limiting your bandwidth...
Aaron
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
»» Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2023
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
