Aug 15th, 2024, 10:51am
Verilog-A Model (Read 1208 times)
bki
Verilog-A Model
Aug 18th, 2014, 6:08am
i never worked with Verilog-A before and now i try to add a model in cadence. I always get errors that i don´t really understand. Maybe someone can help me to correct the model.
It should be a 2 Input AND Gate.
Thats the Code:
`include "constants.vams"
`include "discipline.h"
module V_and(in,out);
parameter real size = 2 from [2:inf),
               vout_high = 5,
               vout_low = 0 from (-inf:vout_high),
               vth =1.4,
               tdelay = 5n from [0:inf),
               trise = 1n from [0:inf),
               tfall = 1n from [0:inf);
input[0:1] in;
output out;
voltage in,out;
integer in_state[0:1];
integer out_state;
integer i;
real vout;
analog begin
@(initial_step)
for(i=0;i<2;i=i+1) in_state[i]=0;
generate i (0,1)
begin
@(cross(V(in[i])-vth))
begin
in_state[i] = V(in[i])>vth;
out_state=1;
for(i=0;i<2;i=i+1)
if(!(out_state && in_state[i])) out_state=0;
if(out_state) vout=vout_high;
else vout=vout_low;
V(out) <+ transition(vout,tdelay,trise,tfall);
The Errors are:
Line 35: "@(cross(V(in[i]<<--?)-vth))" : Identifier ("in") is neither and array nor a vector. Declare identifier as an array or a vector.
:The node array access is out of range. Correct the problem.
Line 30: Encountered an invalid assignment during `generatre`or `genvar`unrolling. Check the validity of the genvar variables.
boe
Re: Verilog-A Model
Reply #1 - Aug 18th, 2014, 7:01am
bki,
First of all, it is recommended to use genvar instead of generate.
Secondly, you should define in as a bus both in the input declaration and in the voltage declaration.
- B O E
PS: please use [ code ] [ /code ] (without the spaces) to enclose code.
cheap_salary
Re: Verilog-A Model
Reply #2 - Aug 18th, 2014, 7:13am
module V_and(in, out);
input [0:1] in;
voltage [0:1] in;
output out;
voltage out;
               vout_high = 5,
               vth =1.4,
integer out_state;
integer j;
real vout;
genvar i;
analog begin
  @( initial_step ) begin
     for(j=0; j<=1; j=j+1) begin
        in_state[j] = 0;
     end //for
  end //initial_step
  for(i=0; i<=1; i=i+1) begin
     @( cross(V(in[i])-vth) ) begin
        in_state[i] = V(in[i]) > vth;
     end //cross
  end //for
  out_state = 1;
     if(!(out_state && in_state[j])) out_state = 0;
  end //for
  if(out_state) begin
     vout = vout_high;
  else begin
     vout = vout_low;
  end //if
  V(out) <+ transition(vout, tdelay, trise, tfall);
end //analog
bki
Re: Verilog-A Model
Reply #3 - Aug 18th, 2014, 7:31am
It works! Thank you!!!
