aaron_do
If you include active elements like diodes or switches then there are other ways to get voltage gain. For purely passive switches, I don' know of any circuit which can give voltage gain at DC.
A transformer obviously can give voltage gain. I think you may have some confusion about LC networks (just read about the L-match) because they can also readily be designed with voltage gain (not just V/I or I/V). For RC, the amount of voltage gain which can practically be achieved might be very limited since they are inherently lossy (unlike LC networks) which is probably why you don't see them. I've never tried this circuit before, I'm just assuming the author wasn't lying.
Aaron
P.S. I just came across this article online called, "AC Voltage gain using just resistors and capacitors?" by Kendall Castor-Perry. You might want to google it...
